07-15-2016 14:55
07-15-2016 14:55
07-15-2016 15:44
07-15-2016 15:44
Hi @Kalahari1
Have moved this thread from the Surge to the Third-Party Integrations section to increase the chance of getting a solution.
Your post will get more attention here.
05:27
09:33
08-05-2016
05:27
09:33
@SunsetRunner Thanks for moving the post
@Kalahari1 It's nice to see new faces around! Currently, Fitbit will sync steps and distance to Endomondo even though you track the exercise it won't sync like that to it. Also, Endomondo will transfer activities to Fitbit.
Hope this helps.
07-15-2016 15:44
07-15-2016 15:44
Hi @Kalahari1
05:27
09:33
08-05-2016
05:27
09:33
Hope this helps.
08-05-2016 17:19 - edited 08-05-2016 17:20
Happy Fitbitting @ most awesome community
Hi Silvia ![]()
Feel free to explore the discussions forums to Share Your Story, Get Fitter, Find wonderful Fitbit Friends, Sharing Recipies and much more.
Best Answer03-16-2017 05:46
03-16-2017 05:46
Hi. I have a problem with the FitBIt - Endomondo connection. All my steps are beeing synced between FitbBit and Endomondo daily but when I use Fitbit for sports (Running etc.) the data is not beeing synced to Endomondo. Why is that so??
Hope some can help me solve this problem. Thanks
03-16-2017
18:07
09:31
03-16-2017
18:07
09:31
It's great to have you here @Ramsli! Fitbit will sync steps, distance, calories and sleep to Endomondo. When you're doing an activity with your Fitbit , it should sync the data mentioned above. However, it won't sync the activity as you see it in your account just the information.
You can learn more about this integration by checking this third-party post.
Hope this helps.
Best Answer08-20-2017 19:36
08-20-2017 19:36
is there any plans to run activity data to endomondo like as fitbit to strava?
10:29
09:32
08-24-2017
10:29
09:32
It's great to see you around @alfiadi! So, each third-party application will sync different things. In this case, Endomondo will sync activities to Fitbit and Fitbit to Endomondo will transfer steps, distance, calories and sleep.
Strava will sync activities to Fitbit as manually logged activities but will not include GPS or heart rate data from Strava. Instead, Fitbit will sync only recorded activities to Strava. You can continue learning more about this by checking this third-party post.
Also, here's the third-party post FAQ to learn more about how Fitbit works with these apps.
Hope this helps!
Best Answer05-04-2018 10:05
05-04-2018 10:05
Is it not possible to transfer Fitbit GPS data to Endomondo?
