03-26-2019
12:43
17:49
SilviaFitbit
03-26-2019
12:43
17:49
SilviaFitbit
I just connected my Versa with My Fitness Pal with the simple of intent of using MFP strictly for entering food (because it's a better tool for that) and having Fitbit work out everything else. I set the MFP to not record steps but I still see it adding workouts and other activities to my Fitbit dashboard that double up on what my Versa has already recorded. i.e. one is clearly from Fitbit and the other states 'from My Fitness Pal' before it but they are the same activity.
Is there an easy way to stop this and just have MFP deliver food info? Thank you!
Moderator Edit: Labels
Best Answer03-27-2019 12:47
03-27-2019 12:47
@Crompsy Welcome to the Fitbit Community! I hope you're doing well!
Thank you for your inquiry. You will need to configure this setting from MFP side. If the issue persist then remove the app (revoke the access from the website and then relink them as you initially did).
Let me know how it goes.
Best Answer03-27-2019 12:54
03-27-2019 12:54
Thanks. I'll give it another shot!
