08-05-2015 13:07
08-05-2015 13:07
08-09-2015 13:39
08-09-2015 13:39
Hey there @Almostfitsarah! MapMyWalk uses built-in GPS to provide runners with the ability to map, record, and share their exercise routes and workouts. Data will sync from Fitbit to MapMyWalk programs. MapMyWalk activity data doesn't sync to Fitbit. This may be the reason you are not seeing data coming from the walk such as steps or distance. However, since you used the tracker in your walk the steps recorded by it are already in the total account for that day. If you didn't use the tracker at that moment you can manually log your walk. To do so, please check this article with the step by step instructions.
I hope this helps. Keep me posted! 🙂
04-27-2016 06:48
04-27-2016 06:48
Hello, I have a Fitbit Blaze but my walks\excercise is not syncing to my MapMyWalk app. I looked at my settings on the MapMyWalk app and it says my Fitbit is connected but nothing is recording from my FitBit
05-02-2016 11:50
05-02-2016 11:50
Welcome to the Fitbit Community @lmarion1965! I think that you need to revoke access to MapMyWalk and then give access to the application again. To connect the accounts, please do the following:
Provided your tracker has synced to Fitbit, logging into MapMyWalk will automatically import your subsequent step history. If this doesn't help, please contact MapMyWalk support for further assistance.
Good luck and keep me posted with the outcome! 🙂
08-17-2017 08:16
08-17-2017 08:16
There is no "Import workout" on my Map My Walk app. Can you tell me where to find this? I just got the Charge 2 fitbit, but I bought it to track my activity to load on Map My Walk with all my friends.
08-17-2017 09:33
08-17-2017 09:33
I have the Samsung 6 edge
08-17-2017 20:02
08-17-2017 20:02
Thanks for stopping by @Billienjosh! To connect your MapMyWalk account to your Fitbit account, you can check my previous post with these steps. However, if you are talking about the MapMyWalk app you'll need to get in touch with MapMyWalk support.
I hope this helps, keep me posted! 🙂
05-02-2020 10:06
05-02-2020 10:06
one thing I do, since it doesn’t adequately record steps or distance is ‘fake’ a walk workout for additional distance and it adds those steps.
