03-04-2017 19:15
03-04-2017 19:15
I have my accounts linked but I can only see my calories on the dashboard but not my steps in MFP. I have seen other people have had this problem but the solutions others have given does not help. The instructions they give you in the Fitbit app just don't make sense with what I am seeing on my phone. I have the updated dashboard.
i tried disconnecting Fitbit from MFP in the MFP app but I just hit disconnect and nothing happens cause when I go back under apps and devices it's there again immediately!! I can't get this disconnected. Help this is super annoying
04-17-2017 04:07
04-17-2017 04:07
Just checked the help pages for MFP. https://myfitnesspal.desk.com/
They are aware of the issue and are working to fix it. They will update as information becomes available.
Best Answer03-05-2017 18:58
03-05-2017 18:58
I am having the same issue. It's been 3 days of it now.
Best Answer03-07-2017 16:17
03-07-2017 16:17
I am having the same issue and cant get it to work.
Best Answer03-07-2017 16:25
03-07-2017 16:25
Just checked my MFP, steps are syncing from Fitbit without problem today and previous days.
This should not be an Android app issue, Fitbit Dashboard backend communication with MFP would be handling this sync.
Best Answer04-03-2017 11:56
04-03-2017 11:56
Did you find a solution? I have the same issue. Mfp isn't showing steps, and fitbit isn't showing the food I'm entering from mfp. Mfp says it's connected with fitbit, but same thing happens when I try and disconnect... Its still there
Best Answer04-03-2017 14:17
04-03-2017 14:17
Best Answer04-16-2017 19:27 - edited 04-16-2017 19:29
The two have been syncing likeva dream until this weekend. MFP posted the problem could be with Fitbit. It is such a helpful team application process with my fitness and weight loss, I hate losing momentum. Why aren't the steps syncing on MyFitnessPal? Thank you
04-16-2017 19:28
04-16-2017 19:28
My Fitness Pal is the product app.
04-16-2017 20:54
04-16-2017 20:54
Having same issue as of today 4/16. Nothing external is syncing
Best Answer04-16-2017 21:15
04-16-2017 21:15
Has anyone figured out which app is causing MFP and Fitbit to not sync? My steps are not syncing onto MFP today 4/16. They synced yesterday. I also tried to un-sync and re-sync according to suggestions and could not get fitbit to disconnect from MFP. Totally frustrating.
04-17-2017 01:29
04-17-2017 01:29
Having the same issue and can't disconnect
Best Answer04-17-2017 03:11
04-17-2017 03:11
I have been having the same issue since 04/16/2017. This seems to be an issue that occurs periodically. I can get it to sync by revoking permission for MFP under settings/applications in the fitbit dasboard on myfitbit.com. Unfortunately it only works for the initial sync after reconnecting.
Best Answer04-17-2017 04:07
04-17-2017 04:07
Best Answer04-17-2017 05:12
04-17-2017 05:12
The food is syncing fine but my steps have stopped syncing since Friday and it's frustrating since I need to see my accurate caloric allotment based on my activity ....
Best Answer04-17-2017 05:13
04-17-2017 06:02
04-17-2017 06:02
I am having same issue. Myfitnesspal is not syncing steps from my fitbit. Didn't sync yesterday either. I've also tried disconnecting and reconnecting app but no joy. 😖
Best Answer04-18-2017 07:48
04-18-2017 07:48
As of yesterday 4-17 my MFP and Fitbit mysteriously started to sync again... No update from either I just woke up to it... I'm glad just hope it doesn't go on the lamb again!!
Best Answer04-18-2017 19:45
04-18-2017 19:45
Solved problem. Found good guidance to go to MFP website ( not app), go to trouble shooting and search "What if data doesn't appear to be syncing from Fitbit to MyFitnessPal?". Go to the section titled "Still no adjustment". Basically going to the Fitbit website ( log in), click gear icon, click on applications, revoke access for MFP (and other apps if not being used. Then wait 15 minutes and then go back to MFP website and relying Fitbit on the main apps page
grampi1
Best Answer04-19-2017 02:11
04-19-2017 02:11
Best Answer04-19-2017 19:04
04-19-2017 19:04
