01-31-2018 17:35 - edited 02-01-2018 17:02
Hi Strava users- I've merged a few posts together. We are aware that the integration between Strava and Fitbit is currently down and hope to have this resolved shortly. I will update this thread as soon as I hear more. Thanks very much for your patience!
Actively managing your weight? Find accountability buddies on the Manage Weight board
02-01-2018 17:02
02-01-2018 17:02
Hi Everyone - We have been made aware that the syncing issue with Strava has been resolved. If you are still experiencing issue, please let me know. Thanks everyone for your patience and reports!
01-24-2018
15:04
05:39
RobertoME
01-24-2018
15:04
05:39
RobertoME
Fitbit not sending my runs over to strava
Moderator Edit: Updated Subject For Clarity.
01-25-2018 00:28
01-25-2018 00:28
Was your run tracked with GPS with a map displayed in the app?
01-27-2018 11:57
01-27-2018 11:57
01-28-2018
18:35
07:44
RobertoME
01-28-2018
18:35
07:44
RobertoME
Cannot connect to Strava. Using the url https://strava.fitbit.com and every single time getting the message:
statusCode | 500 |
error | "Internal Server Error" |
message | "An internal server error occurred" |
Seems to have been an issue last year and all pages reported as "Fixed" - what am I doing wrong and how do I get my Strava account and my Fitbit connected?
01-29-2018 03:05
01-29-2018 03:05
I get the message ‘code error500 internal server error’ when trying to sync my Fitbit with Strava. Can you please let me know the solution? I understand from previous posts that others have experienced this problem.
Helen
01-29-2018 04:21
01-29-2018 04:21
We're seeing the following over here too - and its adding to the list of reasons why I might switch to Garmin, instead of upgrading to a Fitbit Ionic.
{"statusCode":500,"error":"Internal Server Error","message":"An internal server error occurred"}
01-29-2018 04:30
01-29-2018 04:30
This problem comes up with some frequency. The only solution unfortunately is to keep posting about it to grab the attention of FitBit so they can fix it.
It is exceptionally annoying because if they don't fix this before I leave work this afternoon (I ride for my commute) then this morning's ride won't sync. And if it isn't fixed before tomorrow morning's ride, then this afternoon's ride won't sync either. And so on.
01-29-2018 04:52 - edited 01-29-2018 04:53
BankerJoe
wrote:This problem comes up with some frequency. The only solution unfortunately is to keep posting about it to grab the attention of FitBit so they can fix it.
As irritating as I agree it is (and needs to be kept on top of with Fitbit), if you know it is going to be an issue as you set off for work/home, you can just load up Strava and hit the Start button.
01-29-2018 04:55
01-29-2018 04:55
I use Strava for rides, and have that imported into Fitbit.
01-29-2018 05:59
01-29-2018 05:59
Completed my 10k this morning but not picked up by Strava (all my previous runs up to and including last Saturday has uploaded ok) all ok on Fitbit dashboard. Tried resetting with Strava but got error message. Help!
01-29-2018 06:00
01-29-2018 06:00
Unfortunantly it seems that the problem stille exists.
I went out for a run this morning and recorded it with my Fitbit Ionic. When i finished the run it didnot directly upload to my strava accound as is normaly do.
Now there are +- 4hours past and still nothing.
When i try do download the workoutfile manualy i get an errer saying that the file could not be downloaded.
so the problem isent solved for every user yet.
Kind regards.
01-29-2018 06:32
01-29-2018 06:32
Once again, the link between Strava and Fitbit is broken.
01-29-2018 06:35
01-29-2018 06:35
I've also encountered this.
Race sync'd fine yesterday but my commutes haven't sync'd today.
Though on a different note, I had an additional 4km on my race distance to what we actually rode.
I use a Blaze connected to the iOS application.
01-29-2018 07:16
01-29-2018 07:16
Yup, seeing that here too.
Decision matrix:
Garmin +1 point
Ionic -1 point
01-29-2018 07:30
01-29-2018 07:30
I'm pretty fed up with Fitbit as a whole (this issue is one of many). Problem is there doesn't seem to be an equivalent to the Alta HR outside of the Fitbit ecosystem/universe.
01-29-2018 08:12
01-29-2018 08:12
Same issue....can’t sync my workout....
01-29-2018 08:30
01-29-2018 08:30
I'm having the same issue. Tried disconnecting and reconnecting my Fitbit to Strava and now keep getting an error message when I try to reconnect. Have contacted Fitbit support and await a response. Frustrating that this is not more reliable or that there is not at least a message on the Fitbit website when there are technical issues like this. :statusCode":500,"error":"Internal Server Error","message":"An internal server error occurred"}
01-29-2018 08:40
01-29-2018 08:40
May I ask what the error message was? It might be a clue.
Did you get a map of your run displayed in the Fitbit log?
01-29-2018 09:15
01-29-2018 09:15
ahh... see I don't care if Strava doesn't get to Fitbit... but I do care that I had to manually upload my lunchtime run to Strava (irritating extra step I am too lazy to want to do)
