05-14-2015 21:32
05-14-2015 21:32
Hi everyone - I linked my accounts on Wednesday and my first two rides recorded in Strava synced without any issues (Wedneday evening, Thursday morning Australian Eastern Standard Time). I've logged two more rides since then (Thursday evening and Friday monring, AEST) and neither of them have synced to my Fitbit account - I can't see them on the web dashboard or on my iPhone app. Both of them are showing fine in Strava.
I thought the accounts may have been disconnected so I checked and they show as being connected in both web dashboards.
Has there been any issue with the sync service? If not do you know of a way to get it working again short of disconnecting and reconnecting the accounts?
07-17-2015 12:09
07-17-2015 12:09
07-17-2015 12:13
07-17-2015 12:13
07-27-2015 14:49
07-27-2015 14:49
July 20th I ran and I got HR from my Charge pushed to Strava along with my run (and pretty sure everytime before).... on the 22 and now the 27th Strava is no longer getting my HR from the Fitbit push.
Is anyone else noticing this behaviour?
Best Answer07-30-2015 01:01
07-30-2015 01:01
Hi guys,
I'm new to the fitbit scene, but I've been cycling using Stava for years.
I've recently purchased a Charge HR, with the intention of tracking everything OFF the bike. I have a Garmin 500 + HR monitor for that.
I rode at the weekend using my Garmin and everything sync'd flawlessly.....but I rode to work this morning (using the Garmin as usual) and put the fitbit in my bag (as I thought it would turn off it it wasn't being worn, how wrong I was).
Upon arriving at work I logged my Garmin to Strava, no problems there, but it wouldn't sync to fitbit as it already had an activity of 9000+ steps from being in my bag! I guess Strava won't wync over the ride becuase fitbit already has an activity for this period.
If I log the fitbit data as driving, to negate the data, it still won't import the Strava ride!!
Anyone else in the same boat? Or having similar issues?
I thought I could just run off the fitbit, but I see you can't even do that! If I manually log an activity before each ride, it will still think I'm active for this period, and won't copy across the Strava data instead.
Best Answer07-30-2015 03:12
07-30-2015 03:12
Best Answer07-30-2015 04:31
07-30-2015 04:31
Unfortunately I don't think there's a way to turn the Charge HR off (someone please correct me if I'm wrong). I use a Surge for cycling and walking (when I want a GPS) and a Charge HR for everything else. All my Surge data gets into Strava just fine, but I don't have any dedicated cycling stuff (like your Garmin).
What I do find annoying is that with either the Surge or Charge HR (and probably all the other models) even driving in the car or riding my motorcycle adds crazy amounts of both steps and stairs to the record. I wish there was a way to put it into some kind of suspend state (keep the time display but stop tracking steps and stairs) until I turn it back on again. I could live with that, but ideally the Fitbit stuff would be smart enough not to add steps/stairs when in any kind of moving vehicle.
Annoying, but not overly.
Best Answer07-30-2015 04:41
07-30-2015 04:41
Thanks for the reply Eldor.
As you say, it seems silly that there isn't some sort of 'suspend' mode, that ignores what you're doing (and doesn't create an activity for it either!)
...and even more silly is that you can't turn the things off!!
I will try something on the ride home. I'll see if I can sync my Strava data BEFORE fitbit gets a chance to sync. Then hopefully fitbit will accept the Strava data (ie. the proper data) and ignore all the rubbish it records while I'm cycling.
Best Answer07-30-2015 04:45
07-30-2015 04:45
Best Answer07-30-2015 04:47
07-30-2015 04:47
Thanks Scott.
I was under the impression you cannot delete data, just ignore it.
ie. if I log my ride this morning as a drive or walk, I can't then delete it. Or at least, I haven't found out where you delete it completely. Fitbit just seems to negate the data, but still keep it.
Best Answer07-30-2015 04:58
07-30-2015 04:58
Best Answer07-31-2015 09:44
07-31-2015 09:44
Sorry for being a late comer to this thread but just got a charge HR primarily as a Hr monitor for strava and another thread said that it is not possible to export HR data out of fitbit so I'm interested in the comment on recording in fitbit, exporting as walk then changing in Strava to ride. Does this work? if so do you lose any Strava functionality from doing it?
I also saw a comment that if you wanted a cycling HR monitor for strava then you should buy a strava recommended monitor. This I would have done but was convinced by the many press releases from fitbit and Strava on the strava/fitbit integration. 5 hrs in it doesn't seem very integrated to me!
Best Answer07-31-2015 11:21
07-31-2015 11:21
Best Answer07-31-2015 12:22
07-31-2015 12:22
Scott, so if I understand correctly, with a Charge HR you MUST also use the FitBit app in order to first get the data into Fitbit with your heart rate and GPS data from the app. Then that whole shebang gets into Strava, where you change it from a walk to bicycling. Unless you use the app, you'd only get heart rate into Fitbit without any GPS data, therefore nothing would make it over to Strava.
Is that correct?
(Makes me happy that I have BOTH a Surge and Charge HR, so for cycling I simply use the Surge and everything is fine.)
Best Answer07-31-2015 12:25
07-31-2015 12:25
Best Answer08-02-2015 10:19
08-02-2015 10:19
