Sync to my fitness pal
Not syncing correctly with my food diary in my fitness pal
2 REPLIES 2
Is it not syncing at all or are the numbers wrong?
Can you provide some more information?
It might be worth disconnecting / reconnecting your accounts.
Hello @bonwilk! Fitbit shares different information with other apps in different ways. In this case since you're talking about food. MFP is the one that sends the food you log to Fitbit. If your information is not being synced in this way, then proceed with @SteveH's instructions.
Hope this helps.
Fitbit Community ModeratorVivian | Community Moderator, Fitbit
Did this help you? Help others by marking it as a solution! 🙂
