10-09-2014 10:07
10-09-2014 10:07
Hello,
Has anyone been able to get body fat % to sync from the FitBit app to the MyFitnessPal app? My weight syncs perfectly, but body fat % does not.
Any advice? Both FitBit and MyFitnessPal support have no helpful ideas...
10-11-2014 17:59
10-11-2014 17:59
Welcome to the Fitbit Community @jtsmith509! Yes, you should be able to sync your weight and BF% to MFP. If you are not seeing the BF% registered, please unlink and relink both accounts by doing the following:
1. Sign into your Fitbit dashboard.
2. Click the gear icon in the upper right corner and select "Settings" from the drop-down menu.
3. On the left side of your screen click "Applications."
4. Under MyFitnessPal, click "Revoke Access."
5. You can then re-link the two accounts by going to http://www.fitbit.com/apps/myfitnesspal.
After relinking, you can verify that your accounts are syncing by using one of the following data points:
1. On Fitbit you can check for your meal summary and logged activities from MFP.
2. On MyFitnessPal, go to "My Home," then "Check-In." You should see your weight, Fitbit Steps, and Fitbit Sleep Minutes.
I hope this helps you out!
