04-18-2020 02:01
04-18-2020 02:01
I have synced my Fitbit to my Under armour HoVr shoes, however, I cannot are run information syncing to my under armour app?
Best Answer04-18-2020 02:15
04-18-2020 02:15
@SunsetRunner please take a look at this post.
Best Answer04-22-2020 01:29
04-22-2020 01:29
Thanks! The post was somewhat helpful.
I have successfully synced my Fitbit stats to my under armour map my run.
You have to access your Fitbit app, then save your workout in file format (I am using iCloud). Then login into your MapMyRun desktop (this will not work via the app) and proceed to import a file, where you select your saved file (see above) to import. This will give you your workout from your Fitbit now logged into your MapMyRun account 😀
Best Answer04-22-2020 01:33
