12-18-2016 00:41
12-18-2016 00:41
Hi,
I recently started using a Blaze. However i have been using the application Healthifyme to log my food intake for quite some time.
I was able to link the apps via the Healthifyme app, where they provided an option to connect to Fitbit.
However the food and water logs do not appear to be updated in Fitbit app and the steps from Fitbit do not appear in the Healthifyme app.
Do advise how i can solve this. Thanks
17:15
10:47
12-20-2016
17:15
10:47
Allow me to help you @ManasK! Currently, Healthifyme isn't listed as a supported app. This may be the reason why this information isn't syncing. However, since we have an open API you may want to contact them directly for more information.
Hope this helps! Thanks for your understanding.
07-30-2020 01:22
07-30-2020 01:22
Hi,
Has there been any update on this?
11:21
10:48
07-31-2020
11:21
10:48
@SunsetRunner Welcome to the Community. Thanks for getting in touch about this.
Some of our top integrations are noted at www.fitbit.com/us/technology/partnership, but there are many more integrations that aren’t on the list. If you don’t see your integration listed, we recommend contacting the developer of the app for further details.
To find the app developer's contact information, please visit the app store on your phone and see the app's description.
I'll be around if you have any additional questions.
Best Answer02-16-2023 10:29
02-16-2023 10:29
Hi... I have been a good user of Healthifyme app and have followed this below link to sync Fitbit to Healthifyme
https://www.google.com/amp/s/9to5google.com/2022/10/31/sync-fitbit-google-fit-health-connect/amp/
