06-21-2018
07:57
09:26
FerdinandFitbit
06-21-2018
07:57
09:26
FerdinandFitbit
Online it says I can sync with runkeeper to get HR during my run. I have done what the online instructions say to do inside the runkeeper ap to allow access. However, I am not getting HR info into my runkeeper ap. Any suggestions?
thanks
06-25-2018 09:25 - edited 06-25-2018 09:27
Hi there @RolloCarlos. Good to see you in the Fitbit Community Forums! 🙂
I'd like to help with this integration concern you have.
When it comes to HR tracking, it will only work within the Fitbit environment and HR data will not sync to any other app at the moment. If you can see on the Runkeeper support page, at the bottom, where it says "Important things to note", it states the following:
"At this time, Fitbit devices cannot be used as heart rate monitors when tracking directly with Runkeeper. Fitbit's hardware is designed to pair only with their software, so those devices are not compatible with our app at this time."
Hope this answers your question and if you need anything else, I'm always around! 🙂
Ps. I'm moving your post to the Third party integrations board for categorization purposes.
06-25-2018 10:33
06-25-2018 10:33
06-25-2018 10:47
06-25-2018 10:47
No worries! You're very welcome @RolloCarlos!
10-09-2018 02:45
10-09-2018 02:45
I've just purchased a Charge 3 with the hope of pairing the heart rate monitoring with Runkeeper. Is this possible and how?
I've managed to sync my runkeeper and fitbit accounts
Thanks
10-09-2018 12:40
10-09-2018 12:40
@DavidJW Welcome to the Fitbit family! I moved your post to this thread as there are more chances for you to receive an answer to your inquiry here. Thanks for your interest in pairing the heart rate monitor with Runkeeper.
I'd recommend checking the post above which includes an answer to your inquiry. It states the following:
Please check that post above for more details on this.
Hope this helps. Keep me posted!
10-09-2018 13:37
10-09-2018 13:37
Thanks I returned my Fitbit because this was the key feature I needed. Lucky the reseller took it back no problem. Perhaps there needs to be a feature compatible list for each of the popular apps. Shame I really liked the device in the very short time I had it.
thanks
12-10-2018 00:17
12-10-2018 00:17
Definitely a loss for Fitbit lacking this key feature. I think it’s also stubbornness, but they push customers away in this way.
You should really reevaluate this feature to connect HR and sync it with other apps. Otherwise you’ll going to loose more customers on this feature. I will look for other devices now and I will also recommend my network via Social Media not to buy Fitbit as this is still the case.
