Syncing of biking activities between Endomondo and Fitbit
Hi,
I am proud owner of the Fitbit Surge 🙂
I use my Fitbit Surge sometimes to track my biking activities(with GPS on). Previously I was using Endomondo to track my biking activities and I am also a part of biking group on the Endomondo.
Is there any chance to sync my biking activities, with GPS data included, from Fitbit to Endomondo?
Thank you
1 REPLY 1
@Thunder83 Welcome to the Fitbit Community! Awesome, I do biking as well! The only information that Fitbit will transfer to Endomondo is: steps, distance, and sleep. Activities (workouts) made on Endomondo will be transfered to Fitbit. You will need to connect Endomondo with your Fitbit account. Here is how to do it:
  1.  Sign into Endomondo: https://www.endomondo.com/login
  2.  In the top right corner under your name, choose Settings.
  3.  Click Connect and scroll down to Fitbit.
  4.  Select Click here to connect your account. You'll be taken to Fitbit and asked to allow authorization.
  5.  Choose Allow. The accounts will be linked.
Each time your tracker syncs to Fitbit.com, the data will also be uploaded to Endomondo under your workout tab. All the workouts you make on Endomondo are transfered to Fitbit under your manually logged activities. You can always disable this setting by going to Settings > Connect and unchecking Auto-Post New Workouts to Fitbit.
Hope this helps! Happy biking! Smiley Very Happy
Santi | Community Moderator, Fitbit
Like my response? Vote for it! Also, accept as solution!
