06-17-2016 11:33
06-17-2016 11:33
I use both Garmin and FitBit devices including the Garmin Index scale. I see there is an actual integration tool on Fitbit.com to sync with a Withings scale but I can not find instructions to sync with the Garmin scale. I would like to sync my weight data to my FitBit account.
Has anyone tried this? If not, are their plans for future support?
06-18-2016 04:49
06-18-2016 04:49
Don't find any results with 'Fitbit' on their website in the support section.. ![]()
Feel free to contact Garmin
Best Answer10-21-2016 01:40
10-21-2016 01:40
Hello,
Did you find a solution/answer?
10-21-2016 03:14
10-21-2016 03:14
I have not found a solution. I still have to manually enter my weight into the fitbit app.
10-21-2016 11:40
10-21-2016 11:40
@Marsalisjr @arvid_ Welcome to the Fitbit Community! Actually, you can link your Dashboard with Withings Scale just follow this procedure: Go here to use the Withings Connection Wizard.
In regards to connect Fitbit with Garmin devices, it's not a possibility but you may want to vote for this idea Garmin connect integration. Those suggestions are viewed by our engineers and developers.
Hope this helps!
08-17-2019 21:16 - edited 08-18-2019 20:50
@Marsalisjr @arvid_ @Beeny71 @TDA @tdhpn7 @TheGarratt @mi28havoc
A little late to reply here but there's a subscription app Smart Scale Sync that lets you link your Garmin Index scale with various fitness platforms including Fitbit. Likewise you can sync your Fitbit Aria scale with Garmin.
It's also mentioned here: https://community.fitbit.com/t5/Feature-Suggestions/Fitbit-Aria-should-sync-weight-to-Garmin/idc-p/3...
