05-02-2017
01:42
08:51
SelmaFitbit
05-02-2017
01:42
08:51
SelmaFitbit
Hello
How do I sync my surge fitbit to the mobile app my fitness pal? I have tried google and several attempts on the mobile device and a laptop but im still unable to sync the two apps. They are compartable apparently, I just cant get them work.
Thank you in advance
Moderator edit: label
05-03-2017 10:57
05-03-2017 10:57
Nice to see that you're digging into the Forums @bexie-72, let me give you a warm welcome to our Community.
I'll be glad to help you with this, you will have to use a computer to connect both Accounts; follow the steps in this master post to connect MFP accounts with Fitbit. You can verify if they are connected by going to your Fitbit.com Dashboard, on the Settings > Applications.
This should do the trick, let me knkow if you have questions about it.
See you around!
05-03-2017 10:57
05-03-2017 10:57
See you around!
10-10-2018 01:00
10-10-2018 01:00
No good
Still showing no shortcuts
10-17-2018 07:02
10-17-2018 07:02
Hi @bexie-72, thanks for getting back.
I'd like to know what you can see from your end, to have a better idea of what you need to do next. Also you can check more steps here: How do I connect my Fitbit account with another app? If it is connected and not syncing, you need to double check that you Surge is connecting properly; or contact Myfitnesspal support directly.
Keep me posted!
