09-20-2017
18:30
07:42
SantiR
09-20-2017
18:30
07:42
SantiR
Is anyone using Healthtrails? Does it take a little while for fitbit to sync your information to the healthtrails website? I have synced my fitbit and everything is accurate on my fitbit dashboard however it is not sending the information to the healthtrails website.
Any guesses? Please & Thank you.
Moderator Edit: Updated Subject for Clarity
@Sanderella Welcome to the Fitbit family! Thanks for your question! I moved your post to the Third-Party Integrations Board as there are more chances for you to receive an answer to your inquiry here.
If the integration is not working properly; please do the following:
That should help you out. If it is still not working properly; the best thing to do is to contact Healthtrails directly, they will be able to further help you out with this!
Hope this helps. Let me know how it goes!
