Syncing with MFP
ANSWERED
The Alta Fitbit doesn't sync with myfitnesspal correctly. If I go into the app it adds the calorie intake and if later in the day I go into the app it adds the calorie intake again, giving me twice as much calorie intake. Any one else experience this? Can a Fitbit tech look into this?
http://www.myfitnesspal.com/food/diary/fitforlife80
www.fitbit.com/user/3C84MW
1 BEST ANSWER
Accepted Solutions
Hi, @Fitforlife80. I'm guessing this is the same issue that happens from time to time. It's an issue on the mfp end where instead of deleting and replacing a meal when you tweak something about it or add an additional food, it just adds the updated meal. You can delete the duplicate or wrong one from Fitbit. It usually clears up pretty quickly.
MakMak | Community Council
2 REPLIES 2
Thanks @MakMak for your reply.
