I am having trouble syncing my Fitbit Blaze activity to Strava. I am using a stationary spin bike, and using the “spinning” activity feature on my Fitbit. However, after my workouts, the information from the workout (length, distance, calories) will not log automatically into Strava. I have to go and put it in manually. Why is that?
Best AnswerLet's look at the main info post on Strava for your answer @Peddlingpedidoc.
A Fitbit exercise needs to be tracked with GPS for it to sync over to Strava.
GPS does not work when the user is only virtually moving.
Now if you use GPS and sync before turning the recording mode off, Strava will also receive your heart rate.
You may have noticed I moved your none tracker question to the third party board.
