Syncing with my fitness pal
Since Monday, sept 4/17. My Fitness pal is not showing my steps or excerise. I've tried disconnecting Fitbit from my fitness pal but that doesn't work. I can't seem to find where to revoke access from fit bit.
help
thanks
4 REPLIES 4
My sleep isn't tracking right, my fitnesspal isn't syncing..is there a huge problem with Fitbit right now?
Go to your personal settings through the web then click applications, here you can revoke access
Did it. Go to mfp, select Fitbit from apps. Says "disconnect" in a grey button and "buy" in a blue button. Now what?
If you want to disconnect i would say press disconnect.  You will still have to revoke access through the Fitbit link i posted above.
