03-18-2016 11:53
03-18-2016 11:53
Hi,
I've been using a Beurer BG900 weight and I have more than 4 yers of statistics I would like to transfer to fitbit. It is possible to export from the web page of the wight into a Excel sheet, but is there a way to import it to fit bit?
Please help..
Br,
Mads
12-17-2016 12:21 - edited 01-22-2017 10:49
I share this, maybe can be useful:
I have a Beurer BF700 and I develop a software to synchronize the data from Excel to Fitbit, using the Fitbit Web API. The Excel file is generated by the “Beurer HealthManager” Windows software, but basically it contain:
- Column A: date -> cell format must be “Date”;
- Column B (optional): time -> cell format should be "Custom" with "hh:mm:ss" value, or "General";
- Column C: weight (kg) -> cell format should be “Number” or "General";
- Column D (optional): fat (%) -> cell format should be “Number” or "General".
Requirements:
- Windows with .NET Framework 4.6;
- May require administrative rights (right click => run as administrator).
Download link: http://bit.ly/beu2fit
Note: Fitbit limit the Web API usage every hour. You may need to run the app few times on different houres if you have many data. The app will synchronize only the remaining data. You can see the usage limit on the settings (gear icon) of my app.
04-09-2016 08:54
04-09-2016 08:54
Hello @MadsM and welcome to our community. When Fitbit communicate with a third party integration to share information between the two apps it should exist a bond with both of your accounts. However I haven't seen this third party has available an integration with Fitbit, so in other words is not possible to transfer this information. If you need to know more about the available integrations supported by Fitbit, please visit: https://www.fitbit.com/partnership
See you around in the community.
09-26-2016 05:28
09-26-2016 05:28
If you have an iPhone, you can synchronize your data from "Beurer HealthManager" app to "Apple Health". On HealthManager, enable the option under Settings.
Then with the "Sync Solver - Health to Fitbit" app, you can synchronize from "Apple Health" to Fitbit.
12-01-2016 14:15
12-01-2016 14:15
Hi Mark,
Thank you for your help and reply, but unfortunatly my Beurer BG900 weight does not work with the "Beurer HealthManager". The Beurer BG900 weight is to old and is not avalable for syncing with the app.. What I tried asking fibit was if it is possible to import data from a ecxel sheet as the old website that my beurer weight uses has an option to export all of the data to an excel sheet...?
Requirements:
12-19-2016 08:39
12-19-2016 08:39
WOW! Thank you Mark. I will try this as soon as possible and give you an update on how it went!
01-09-2017 02:59
01-09-2017 02:59
If it does not work, is may due to the fact, that Beurer website generate Excel files formatting as text the date and the time cell. By changing them in Excel, it should work. That’s required in order to read the data behind the different regional format.
01-11-2017 07:35
01-11-2017 07:35
Hello Mark..Thanks for you job.
Unfortunately I try to upload from the exel file but I got an error.
I checked and change the format of the cells as you wrote in the previous posts
Thanks in advance for your support
Save
01-11-2017
08:32
08:44
RobertoME
01-11-2017
08:32
08:44
RobertoME
Hi Save,
I sent you a private message.
Best Regards,
Marco
Update:
PLEASE NOTE
HealthManager Web
Currently, the Excel files generated by the https://connect.beurer.com/HealthManager/ website, have problems. The date aren’t always correct, sometimes day and month are inverted. And the cells aren’t properly formatted. Beurer is aware of the issue.
HealthManager Software for Windows
For the owner of a Beurer device compatible with HealthManager, an alternative is to use the Windows software. As isn’t much user-friendly, I wrote the quick manual “How to safety export your Beurer weigth data to Excel” available from: http://bit.ly/beu2fit
HealthManager app for Smartphone
Eventually, you can also export the data to PDF, using the Beurer HealthManager app for smartphone.
Beu2Fit
Then, you can use the exported file - doesn't require any change - to upload your data to Fitbit using Beu2Fit (also available from http://bit.ly/beu2fit).
Best Regards
Moderator Edit: Format
01-18-2017 05:42
01-18-2017 05:42
Hello everybody,
I want to say a public "Thank you very much" to Marco that support me and us to the develop of a application that upload the Beuer Weight Scales result to Fitbit.
With this tool I uploaded 2 and half years of weights and % fat on the fitbit portal.
Thanks again Marco
Nice Job
Save
02-16-2017 07:19
02-16-2017 07:19
Hello again Mark,
I have finally gotten the time to sit down and try this. My Problem is that I use a different beurer site to manage my account and it makes a different setup on the excell sheet and I am having problems changing it so your program accepts it. Do you have an exampel excell sheet I can use a guide? My beurer weight is unfortunatly not compatible with the health manager.. 😞
best regards
Mads
02-16-2017 07:39 - edited 02-16-2017 08:19
Hi Mads,
I uploaded a sample file in http://bit.ly/beu2fit
Also please download and install the latest version of the app (always from http://bit.ly/beu2fit).
Best Regards
02-16-2017 12:15
02-16-2017 12:15
Perfect! Thank you so much Mark. I got it working now and have started the work of getting almost 5 yers of input over to fitbit! Takes a while with the houerly limit from Fitbit, but worth the wait!
Thanks again Mark!
Best Regards
Mads
09-09-2017 07:23
09-09-2017 07:23
@Mark81 wrote:PLEASE NOTE
HealthManager Web
Beu2Fit
Best Regards 😉
hi,
i found this topic by googling about syncing beurer scale infos to google fit. I was trying to develop something similar to your Beu2Fit for my BF480, but using Google Fit API's in JAVA, for desktop use. First problem was about getting data and I found that all the infos are stored in a MDB file under %APPDATA% folder (if you need mode info write me in private). Second problem was about sending data somewhere else (but is OT as it's about google fit). My final goal is to extract data directly from the scale but this requires too much effort in USB reverse enginnering and stuff (and yes is OT.. sorry). Maybe my solution to get data without exporting excel file can be useful to improve your Beu2Fit, let me know
09-09-2017
08:17
08:59
RobertoME
09-09-2017
08:17
08:59
RobertoME
Thanks for the solution. Works perfectly for me
09-16-2017
05:34
08:47
RobertoME
09-16-2017
05:34
08:47
RobertoME
Hi Anxdroid, thanks for your kind collaboration, that’s interesting! But unfortunately currently I can’t dedicate much time on this project. Maybe a little further! In any case, I think that first is required a written consent from Beurer, otherwise I can't consider to share it.
Thanks Asmrussel for your feedback!
Update:
I share another app developed a few months ago. Don’t have time to officially release it for the moment, so I start to share a preview working edition, with the purpose to help users to upload their body data on Fitbit.
Name:
WeightHub
Privacy Policy:
I don’t collect any user data.
OS supported:
Cloud:
File:
Download link:
http://bit.ly/weighthub
Note:
On Windows 7, if the texts should appear pixellated, disable and reactivate ClearType from the Windows display settings.
Have fun!
09-16-2017 06:49
09-16-2017 06:49
WeightHub is much easier to use and fun. First Time its take me some time to understand the left side menus. Thanks for your great work.
10-08-2017 04:15
10-08-2017 04:15
If you installed WeightHub 0.1.0, please update to 0.1.1, due to this vulnerability: https://nodejs.org/en/blog/vulnerability/september-2017-path-validation/
06-10-2018 12:14
06-10-2018 12:14
Hi Mark,
Thanks for developing this solution!
Are you still actively supporting the app? I have a problem using it in Linux. I try to sync a file I've downloaded from my Beurer account to sync it to Google Fit or Fitbit. The file loads without a problem, I can see all the data from the file in WeightHub. Then I click continue and there's a message what will be uploaden. In the final step I get an error "The operation failed."
Any idea what I am doing wrong?
All help appreciated!
06-11-2018 11:43
06-11-2018 11:43
Hi Dajohn,
Yes, I still support the app, but I have limited time to dedicate.
I tested it on Ubuntu x64, with your general settings (as showed on the picture), and I was able to synchronize the measurements. So, unfortunately I wasn't able to reproduce the issue.
Which OS are you using? Under 32 or 64 bit?
Thanks!
