01-14-2019
12:51
11:29
FerdinandFitbit
01-14-2019
12:51
11:29
FerdinandFitbit
Help needed
How do I get mt data from fitbit blaze over to my garmin 820 so data can be seen on garmin connect, Want to add my steps on this app
Regards
Wangle
Moderator edit: Updated title for clarity
11:28
04:07
01-16-2019
11:28
04:07
Hi there @Wangle, welcome to the Fitbit Community Forums! 🙂
When it comes to transferring your data to another tracker/app, you can only do this if the app you're tranferring your data to is partnered with Fitbit. To see the list of the compatible apps, click here.
This means that at the moment, you will not be able to transfer your data over to Garmin.
If you need help with anything else, I'm always around!
PS. I'm moving your post to the Third Party Integrations board for categorization purposes.
01-29-2019 13:48
01-29-2019 13:48
@Wangle the Garmin site has a process outlined. Please note, it currently indicates it is not operational, though there are comments in the Garmin forums that it is working. I have not personally attempted this:
