10-30-2015 04:54
10-30-2015 04:54
I have a Withings Smart Body Analizer sending readings to my Fitbit account - and than from Fitbit to Trendweight and MFP. The scale have sendt todays reading to Fitbit and further to MFP but not to Trendweight.
Anyone else experiencing this today? Could it be caused by the maintainance this mornning (morning in the GMT+1 sone)?
Best Answer11-06-2015 06:14
11-06-2015 06:14
Hi there @jorang. It's good to see you around! 🙂
I've not heard of other users having issues with this or at least not as a major issue. I'd recommend going to your settings and then to the apps tab on your account and revoking access to Trendweight. The option should look as in the image below:
Once you have revoked the access, go to Trendweight and link it back to your Fitbit account and this should resolve any issue of data not properly transfering.
Hope this helps and let me know if you need more help!
Best Answer11-09-2015 01:24
11-09-2015 01:24
Thanks for the tip @FerdinandFitbit.
Without revoking/ relinking the flow of data started again a few days later. Last saturday the same problem were there again. Not possible for me to tell if the problem was on your side - or on Trendweight's side, but it's OK by now
Best Answer11-09-2015 05:55
11-09-2015 05:55
Thanks for getting back @jorang! I'm glad to hear that it's all working fine now and well, I wouldn't be able to tell on which side the problem is but if you notice the same problem happening again, please let me know! 🙂
