01-05-2017 19:44
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
01-05-2017 19:44
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
- Who Voted for this post?
I used to have a Flex and now have a One. Since I registered the One it is not syncing g with my fitness pal. I was told to revoke access and start over. MFP shows my fitbit is connected and won't disconnect. My fitbit does not show that my fitness pal is connected so I can't revoke access. I'm confused. Maybe I should delete both and start over? Thanks for help!
Accepted Solutions
01-07-2017 05:51
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
01-07-2017 05:51
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
Thanks for joining us to this family @Lb0456, hope you like what find here! Fitbit One! good choice. The troubleshooting step that you're trying is the correct, if your One is currently syncing you can try that step again, to make sure that they are disconnect try this steps and then relink them using the information in this post. It's best to use the computer instead of the App to do so. Also make sure that they are disconnected before to relink them by logging out and back in from the Accounts.
Good luck! I'll be around in case you need anything else.
01-07-2017 05:51
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
01-07-2017 05:51
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
