11-06-2014 09:01
11-06-2014 09:01
From bodbot.com I clicked "connect my fitbit" and I got this error:
it was not possible to access the OAuth request token: it was returned an unexpected response status 400 Response: {"errors":[{"errorType":"request","fieldName":"n/a","message":"This request should use https protocol."}],"success":false}
I thought it was an issue with bodbot.com, but then today I saw that I can now connect fitbit with another website I use and got the same error. I would really like to connect to these apps...please help!
11-06-2014 19:24
11-06-2014 19:24
I think you need to get with BodBot.com.
I do not think its a fitbit Problem
Wendy | CA | Moto G6 Android
Best Answer11-20-2014 11:06
11-20-2014 11:06
@frappyhappy18 Hey there! You may want to check the list of compatible apps. As @WendyB mentioned it's better to contact BodBot.com because the app isn't listed in the main apps.
Best Answer03-10-2018 16:00
03-10-2018 16:00
Did you ever get a solution?
Best Answer03-15-2018 06:29
03-15-2018 06:29
It's great to have you here @sashaogomez! You may want to check the list of supported apps. Currently, Bodbot isn't one of the apps yet. However, you may want to contact them directly in case they have any workaround.
Hope this helps!
Best Answer03-15-2018 12:40
03-15-2018 12:40
03-16-2018 09:14
03-16-2018 09:14
I'm glad to hear that it started connecting after you posted @sashaogomez! I'm pretty sure people that were asking about connecting both apps will enjoy it now.
Hope I can continue seeing you around! ![]()
11-05-2018 04:56
11-05-2018 04:56
How was you able to connect bodbot with it. Bern trying for weeks.
Best Answer01-28-2020 15:40
01-28-2020 15:40
I just tried connecting Bodbot to Versa 2 and got same error message. **ahem** shame. Really hope it connects one day
Best Answer04-06-2020 14:07
04-06-2020 14:07
Just started happening did you eventually get it working?
