I started using MyFitnessPal again and can't get my Fitbit Ultra to sync to the app. I had this problem before but this time can't get it to work.
Hello @BJ64, good to see you around! In this case note that your Ultra will only sync with your Fitbit Dashboard and from there your information will be shared to your MFP account? So you need to make sure your Ultra is syncing with your Fitbit account:
Keep in mind the Ultra syncs in a different way from the other Fitbit trackers.
If you use a PC, plug your base station into a USB outlet in your PC. Look for the Fitbit icon in the lower right corner of your system tray.
If the icon is teal and gray, your base station is working.
If the tracker is syncing but you are not able to see data on MFP, then try the suggestions from this post. I'm sure it will provide you more details.
Hope this helps and let me know how it goes.
Hello @BJ64, thank you for keep me posted and let me know you are able to sync your tracker.
If the issue is isolated to the integration to MFP then the best solution is to revoke the access of this integration. Although for what I can see, you already tried this to no avail. Either way I'm gonna share with you the process to revoke the access here, perhaps there is something missing that might help to resolve this issue.
At this point my recommendation is to approach to MFP customer support to learn more about if there is an issue in the integration.
See you around. For more questions feel free to keep me posted.
I have followed these directions multiple times. Fitbit is still not transferring my steps to MFP.
