02-03-2025 06:44
02-03-2025 06:44
Hi there, I have been trying to synch my Inspire 2 to Nutracheck as I had a problem with this. I have ticked the box in Nutracheck to link it to Fitbit and I revoked access to Nutracheck on the Fitbit app to prompt relinking. However, I cannot see a way to unrevoke this access and the 2 apps are of course not synching. Can anyone help please? Thank you,
Best Answer02-03-2025 12:43
02-03-2025 12:43
Hi @JaneK1314 once you revoked access to a third party, you will need to setup the sync as if you are just starting. In this case go to Nutracheck and setup the fitbit connection. At this time you will be asked to accept/grant access on fitbit.
Best Answer02-03-2025 12:49
02-03-2025 12:49
Best Answer02-04-2025 01:46
02-04-2025 01:46
This is a Nutracheck issue. Are you following these steps? If so you should contact Nutracheck.
Best Answer02-04-2025 01:48
02-04-2025 01:48
I'm following the steps recommended. Thank you - I'll contact Nutracheck. Thank you for your help.
