05-19-2019 04:44
05-19-2019 04:44
Hi,
i was wondering if anyone has managed or is it possible to link the wahoo blue sc cycle speed and cadence sensor to the ionic? I use my bike on turbo trainer as well so am
looming for a data input for the ionic as I do t take my phone with me! Or does anyone have an alternative solution?
05-19-2019 11:04
05-19-2019 11:04
Hi @Razorsharp78 . I’ve moved your post to this forum where you will be more likely to find an answer. If you do not get an answer, you can try searching for an answer in the Community Forums. Or even Google, since that may show results from Wahoo’s site.
05-19-2019 11:04
05-19-2019 11:04
05-19-2019 11:05
