10-01-2014
08:20
12:34
AngelaMa
10-01-2014
08:20
12:34
AngelaMa
Any advice from fellow Weight Watchers and integration of Fit Bit and Plan. Also using Active Link and love the point exchange. Does that continue? How do you enter foods? All info needed. Thanks.
10-01-2014 08:45
10-01-2014 08:45
It has been great adding the fitbit to WW. You still do everything on the WW app for entering your food, but the fit bit activity shows up and exchanges to available points to eat. You just change your device in the WW setting to read your fitbit activity. Hope this helps.
10-01-2014 11:22
10-01-2014 11:22
@pj-d You can only link one device on the WW site. If you are using the AL I would leave it linked as there are many problems right now with the fitbit being linked at WW
Some people use My Fitness Pal to add foods.
I just use WW to add foods and dont add it here.
But thats up to you
Wendy | CA | Moto G6 Android
10-02-2014 12:59
10-02-2014 12:59
