06-26-2017 07:22 - edited 06-26-2017 07:34
Hi,
I bought a Nokia Body+ scale (formerly known as Withings) and paired my Fitbit account with Withings (www.fitbit.com/weight/withings). The sync works fine but the values are shown wrong. I often have differences in the range of 0.1.
I.E.: My scale says 97.2, the Withings app says 97.2 but the Fitbit dashboard says 97.1.
The answer shows up if I export my data from Fitbit backend.
The exported value is 97.17 for this day. The Fitbit dashboard and the app doesn't round this value correctly to 97.2, it truncs the last digit off.
Same problem with the fat percentage.
Please fix this issue.
Best Answer06-27-2017 08:45
06-27-2017 08:45
Interesting. I dropped by because mine has stopped importing completely since the change from Withings to Nokia and wondered if anyone else was having a problem.
Best Answer06-28-2017 06:23
06-28-2017 06:23
I bought my scale one week ago, so I started after the change from Withings to Nokia. The synchronization itself works without any problems. The values are transmitted nearly in real time.
But they are displayed wrong -- the rounding issue I mentioned above.
Have yout tried to unpair the accounts and pair again?
