Weight not match what entered in to MFP
I've noticed an odd trend.
Depending on what screen I am on my weight shows different.
Look at the screen shot.  one side it says 19.9 the other side it says 19.6
Here is the kicker  - I only enter in 0.5 lb inciriments. So where is it getting these decimal points?
Confused!
1 REPLY 1
@Kerivkennedy A warm welcome to the Community! Thanks for the screenshot that you shared. The reason why you're seeing different weights is because each one is giving you different information. As an example for the 19.9 that's the weight you've lost for the past 3 months. The 19.6 is what you've lost since 12/18.
Finally for 0.5 that's what you've lost during that week.
Just wanted to add this information, MFP will sync activities and food to Fitbit. Fitbit will sync steps and weight to MFP.
Hope this helps Robot Happy
