04-09-2019 17:20
04-09-2019 17:20
Hi, I am not sure if this topic has been posted before but...
Basically, I just enrolled myself in a spinning studio and they uses an app called Spivi. I would like to link my HR data to their app however they state that only devices with ANT+ technology can do.
I own a Charge HR which doesn't support ANT+ so my question is, at this moment, which fitbit product supports ANT+ tech?
Thanks so much for your time and reply!
William
Best Answer04-09-2019 19:46
04-09-2019 19:46
Unfortunately, no Fitbits have/support ANT+.
04-09-2019 19:46
04-09-2019 19:46
05-03-2019 12:12 - edited 03-03-2021 14:00
At one time Fitbit advertised that the ionic will eventually get the ability to connect to a third party HR chest strap. I wonder if this has been scrapped.
01-30-2020 12:28
01-30-2020 12:28
If your fitbit is working well, just get a cheap $35 strap. No need for dual smart monitors.
Best Answer01-30-2020 12:43
01-30-2020 12:43
@Pmheart6 wrote:If your fitbit is working well, just get a cheap $35 strap. No need for dual smart monitors.
What good is a chest strap sensor if you cannot see the readings?
03-03-2021 08:28 - edited 03-03-2021 08:29
Many strap HRMs have an app that will display your HR. If you want something that will integrate into FitBit, I don't think it exists.
