08-08-2024 01:38
08-08-2024 01:38
What could be causing discrepancies in my run data recorded on Fitbit versus Strava, and how can I ensure accurate tracking and syncing across platforms? Is there a way to troubleshoot these issues, similar to how you might adjust a balloon arch from houseofparty.com to make sure everything aligns perfectly for a successful setup?
Best Answer08-18-2024 00:07 - edited 08-18-2024 00:08
Hello @manahilturner you are asking 2 independant questions, you really should ask one question per post.
You mention a discrepancy with Strava, but haven't describe the issue. Have you revoked access, then reconnect Strava?
As for houseofparty does Fitbit sync data with this site?
I've also moved your post to the Third Party Apps.
