05-01-2020
16:03
13:23
SilviaFitbit
05-01-2020
16:03
13:23
SilviaFitbit
If I use these apps (Run, Walk & Bike) on the phone for the accuracy of the GPS? Will it display the map on my Fitbit Dashboard? I currently did a walk on “MapMyWalk” and the data for Distance, Time and GPS (map) didn’t transfer over to the Fitbit App. Just shows “Walking (MyFitnessPal)” and has the time and calories, but no Distance or Map data.
05-19-2020 13:28
05-19-2020 13:28
@keithpanamick It's nice to see you on the Community. Sorry for the delayed reply.
Thanks for letting me know that you're using Fitbit and MapMyWalk. The information shared between MapMyFitness Apps and Fitbit is distance and calories from Fitbit to MMW. Instead, MMW won't sync any data to Fitbit, this might be the reason why you got only duration and calories burned.
You may want to check more integrations here. If you don't see an app there, it doesn't mean that's not compatible, it's best to check on their side as Fitbit doesn't manage any third-party integration.
I'll be around if you have any additional questions.
