02-01-2015 09:22
02-01-2015 09:22
Can I make Withings app use the fitbit tracker instead of the iPhone?
Thx
02-03-2015 09:28
02-03-2015 09:28
Yeh, I have it linked to the scales. Was hoping Withings would pull the steps from FitBit rather than iPhone.
Thanks for the replies. 🙂
02-03-2015 06:21
02-03-2015 06:21
Withings will send data to whichever app it is connected to. Use the Withings Connections Wizard to connect Withings with your Fitbit account. This way your recent weight from Withings is automatically updated and added to your Fitbit profile - and used by your tracker when syncing it to your Fitbit Account
02-03-2015 09:12
02-03-2015 09:12
@SunsetRunner You cannot directly connect your tracker to the Withings app. The best you can do is link the accounts as the other poster mentioned. However, I believe the only data you will see in your Fitbit account is weigh-ins from a Withings scale.
02-03-2015 09:28
02-03-2015 09:28
04-03-2015 11:51
04-03-2015 11:51
This is not letting me connect the two accounts. I keep getting the below
"Unable to authenticate Withings user. Withings server returned the following error: The userid and publickey do not match, or the user does not share its data."
04-04-2015 11:23
04-04-2015 11:23
Did you ever get this resolved? I am getting the same error trying to use the Withings Connection Wizard and I have verified that I'm using the correct login.
04-04-2015 13:33
04-04-2015 13:33
@DesiK wrote:Did you ever get this resolved? I am getting the same error trying to use the Withings Connection Wizard and I have verified that I'm using the correct login.
No and support were not much help
04-04-2015 13:46
04-04-2015 13:46
04-04-2015 16:43
04-04-2015 16:43
@DesiK wrote:
That's disappointing. I haven't been able to find anything in other discussion boards to help, either.
Lets hope they solve it this coming week.
04-06-2015 04:22
04-06-2015 05:17
04-06-2015 05:17
04-06-2015 05:33
04-06-2015 05:33
@DesiK wrote:
FYI, I decided to use IFTTT to set up the connection instead and it works perfectly.
I might try that. Will it sync weight and body fat % etc?
04-06-2015 05:34
04-06-2015 05:34
04-06-2015 12:41
04-06-2015 12:41
@DesiK wrote:
Yes, it syncs both.
Thanks. I have set one up but its not updating. Its saying the IFTTT has never run. Can I ask how ofton does yours update?
04-06-2015 15:12
04-06-2015 15:12
Mine updates within minutes. This is the one I am using: https://ifttt.com/recipes/176141-if-i-weigh-myself-with-my-withings-scale-update-my-weight-on-fitbit...
04-07-2015 06:04
04-07-2015 06:04
Thats funny as its not running for me. 11h and its saying its never run
04-11-2015 09:42
04-11-2015 09:42
FYI, I just followed these instructions that I received from Fitbit Support and the connection wizard is now working for me:
Please try clearing your browser's cache. Directions on how to clear your cache on a variety of browsers can be found here:http://www.wikihow.com/Clear-Your-Browser's-Cache.
After clearing your browser's cache, please opend two different Chrome windows, log in to your Fitbit account in one of the Chrome's and log in to your Withings account in the other. Try to link the accounts, this way you'll received a different message by doing this, this way your accounts will be linked.
06-19-2015 21:19
06-19-2015 21:19
10-09-2017 06:09
10-09-2017 06:09
Thank you so much! I was able to sync because of your suggestion! A huge help! Thank you!
01-29-2018 12:22
01-29-2018 12:22
The solution works for me.
keep in mind that your logon name is case sensitive
