06-27-2017
12:00
06:39
RobertoME
06-27-2017
12:00
06:39
RobertoME
In the past, I always manually entered my into MyFitnessPal and FitBit would pull it from there. While I never used my FitBit for nutrition tracking, it was handy to be able to see my current weight and goal as it helped motivate me to move more. Recently, I purchased a Withings Body Cardio because I got a fantastic deal on it. So I linked that into MyFitnessPal as well. So basically, my setup goes as follows:
Withings <--> MyFitnessPal <--> FitBit
While the Withings automatically updates my weight in MyFitnessPal, FitBit no longer pulls that updated data from MyFitnessPal. Is there a setting I need to change? Do I have to change the link order? If I do need to change the link order, will this affect how one updates the other?
Moderator Edit: Updated Subject For Clarity.
Best Answer07-01-2017 06:37
07-01-2017 06:37
Hello @Bradcore, it's nice to see new faces in the Fitbit Community! In this case it depends on what information syncs within your accounts including Fitbit. As you mentioned, while MFP is great handling nutrition data not all the information from MFP will be pulled by your Fitbit account, however if are weight logs this should be share to your Fitbit account
So in these cases the best to do is to revoke the access of the integration. For more details please take a look at this post.
For more details about which information syncs MFP with Fitbit please visit the following post.
Hope this helps, catch ya later!
