12-09-2015 18:44
12-09-2015 18:44
I have started using a Surge and so far (2 days) things are going well, except for syncing my workouts with Endomondo. The daily steps synchronize as they are expected and I am able to export my bike rides, which is cumbersome, but doable, but when doing a workout with weights and tracking with the Surge, the workout doesn't show in Endomondo and is not able to be exported and then imported. If I enter the workout in Endomondo, then it is duplicated in Fitbit and it shows two workouts for the same time.
How are others handling using Endomondo, or other application?
Is there any chance that either Fitbit or Endomondo will be making a change so that 2-way integration will work?
Best Answer12-09-2015 18:55
12-09-2015 18:55
I now see that when I am importing the workout into Endomondo using the TCX file, it is duplicating the workout in Fitbit. Is this correct?
