I just joined my fitness pal and on that app it says my fitbit is connected. I see exercise but I don't see my daily steps anywhere. Can you tell me if I need to "connect" to fit bit and how to do that? I see I have weight watchers there but my fitness pal is not there. thanks!
Best AnswerHi @SunsetRunner
To confirm your connection between your MyFitnessPal and AppGallery Partner log on MyFitnesspal , then go to AppList
If Fitbit Tracker isn't listed under Your Apps add it from the App Marketplace
