can i synch my fit bit to my map my run account??
ANSWERED
Just wondering if i can synch my fit bit to my map my run account?  I am a runner & i know the mileage on the map my run app is accurate however my fit bit is definitely coming up short.  I know that i need to adjust the stride but in the mean time????
1 BEST ANSWER
Accepted Solutions
3 REPLIES 3
There's some information on this here:
https://www.fitbit.com/apps/mapmyrun
thanks steve, I swear i looked all over for this & couldnt find it,
Ok, yes you can take your Fitbit Surge workout, export it into a .TCX file and then import it into the Mapmyrun app, but that is a total pain.  It seems to be doable from a PC, but not from a mobile device - I have tried to find a way to do it from my iphone and from my ipad - no luck.  I bought this device because it is supposed to sync - you can connect the device into your MapMyFitness apps, the steps sync but the workouts do not.  This is pretty worthless.  I want my workouts to seemlessly sync.  I hate having to wear my Fitbit Surge AND my TomTom runner just for syncability.
