02-06-2016 14:40
02-06-2016 14:40
I am not having issues where my charge HR is counting my calorie burns in MFP 2-3 times for example. if I do an exercise and burn 325 calories it will log it 2-3 times. or If say I talke a walk and burn 100 calories and then workout later and burn 250 it will count the walking 2-3 times. I am also having issues like,If I burn say 100 calories it will give me say 10 calories,then it will give me 5 and then back to 0 and then it will give me 4. whats up with this? I had to un sync my fitbit with mfp for now
02-07-2016 07:55
02-07-2016 07:55
Welcome to the forums @Tracey74! I'm also a MyFitnessPal user and I'll be glad to help on this.
I have seen this situation happen whenever both accounts don't have the same caloric budget to work with; so I recommend to disable Fitbit's Food Plan and add your MFP caloric budget as a main calorie goal.
I'll show you how to do it from my profile information.
First, you'll need to go to your Food log page and click on the arrows on Food Plan until you see the option "Edit Plan".
After you've done this, click on "Set a new Goal"
Add your starting weight and your desired weight and click next.
Instead of choosing the food plan options provided by Fitbit, click on "Set my own Calorie Target".
Now on MyFitnessPal, click on Goals and (unless you have an specific nutrition goal) click on "View Guided Setup"
Now on your Diet profile, add all the information required.
Now, you will get a Net calorie target for the day. Please bear in mind that mine is low because of my settings, but yours will be different.
Now, go back to your Fitbit Screen and add the Net Calorie target you were given for the day and click on Done.
Now you're set! The food you log in from MFP will automatically edit your Fitbit caloric values for the day and it will reflect on your MFP calorie budget for the day.
A couple things to consider about this:
Hope this helps! Let me know if you have any questions
02-07-2016 11:36
02-07-2016 11:36
02-07-2016 11:37
02-07-2016 11:37
I am maintaining my weight for right now and fitbit will not let me manually enter the calories mfp gave me for that. my weight of both apps were the same and I was not having that issues with it giving me all those calories(or lack of) until recently
02-07-2016 11:42
02-07-2016 11:42
it wouldnt let me change it so I set it to lose 9 lbs and will set mfp accordingly and see if that helps.
02-07-2016 11:50
02-07-2016 11:50
ok so update to the changing the weight loss part. fitbit says I have 910 calories left for the day and mfp says 927 and they are both set to 1560 but fitbit now shows 1543. they are not syncing up properly even though they are set up as the same amount of calories
02-07-2016 11:55
02-07-2016 11:55
had to fix it through the fitbit page,again But,its not showing on the phone app as being fixed,it asks me to start a food plan. restarted my phone too ,I cant set it manually through the phone app
02-09-2016 06:54
02-09-2016 06:54
Thank you for your responses @Tracey74! Here's the trick: when you base your food plan on MFP's settings, your In vs Out gauge will be disabled. This is because your caloric information will be displayed on MFP's screen:
Let me know if you have any questions!
