01-05-2017 03:35
01-05-2017 03:35
My fitbit is not syncing with myfitness app. I have installed and reinstalled both apps. The myfitness app no longer lists a section for calorie adjustment as it did when it was syncing with fitbit.
01-06-2017 09:51
01-06-2017 09:51
It's nice to have you in the Community @msmonaotr! You can unlink and relink both applications by doing this procedure. After this, you can double check that this was successfully unlinked by going to your Dashboard > click on settings > applications and there you shouldn't see "MyFitnessPal".
Hope this helps!
