09-19-2016 14:17
09-19-2016 14:17
Whenever my Endomondo app sync's with My Fitness Pal, my Fitbit stops syncing. I then have to come online and disconnect it and then connect it again. Any ideas why this is happening?
Best Answer09-23-2016 09:27
09-23-2016 09:27
Allow me to help you @Jackie19! This is pretty weird. Endomondo and MyFitnessPal sync different information between them. Even though you have both apps linked to your Fitbit, this shouldn't be an issue because they will sync automatically.
I think the issue is more related to your Fitbit tracker and not to your third-party apps. I would like you to check your Dashboard and see when was the last time it synced. If it hasn't synced then your data won't be transferred to your apps. In case you're having syncing issues then follow this iOS, android or computer troubleshoot.
Hope this helps. Let me know how it goes.
