03-07-2014 12:00 - edited 03-07-2014 12:02
Ok , I have a qurstion, after recently buying a mio alpha and polar loop. I like the heart rate tracking with the activity tracker. But love my flex and want to add the aria for a full body measurements/tracking. However I want to add calories from heart rate/workouts. So is there any app/site that data can be exported to that will combine fitbits step/distance with data from a heart rate monitor. Digifit comes the closest but can't combine a workout with my heart rate. Unless the premium version does it I don't know. Any ideas? (Negatives on the polar loop, no ability to use WiFi scales and doesn't give distance traveled)
03-13-2014 14:35
03-13-2014 14:35
I have the exact same question...
I also have a Mio Alpha, Flex & Aria.
Thanks
03-28-2014 16:43
03-28-2014 16:43
Same Here!
@kevtoon wrote:Ok , I have a qurstion, after recently buying a mio alpha and polar loop. I like the heart rate tracking with the activity tracker. But love my flex and want to add the aria for a full body measurements/tracking. However I want to add calories from heart rate/workouts. So is there any app/site that data can be exported to that will combine fitbits step/distance with data from a heart rate monitor. Digifit comes the closest but can't combine a workout with my heart rate. Unless the premium version does it I don't know. Any ideas? (Negatives on the polar loop, no ability to use WiFi scales and doesn't give distance traveled)
03-28-2014 21:09
03-28-2014 21:09
The simple method is to edit your activities in your Fitbit dashboard and enter the number of calories burned according to your Mio. I personally input calories burned from my Polar HRM in my Runkeeper activities, which sync to Fitbit via MFP. There are a few ways to accomplish what I believe you're trying to do.
04-08-2014 10:39
04-08-2014 10:39
Sam | USA
Fitbit One, Macintosh, IOS
Accepting solutions is your way of passing your solution onto others and improving everybody’s Fitbit experience.
04-23-2014 11:33
04-23-2014 11:33
I too use Digifit and Mio Alpha; the combination with Fitbit means much more accurate calorie burn values for workouts. The Digifit website gives a very good set of data visuals incorporating Fitbit values too. Provides really good insentive on diet and exercise. This combination has helped me lose 22lbs in 42 days.
07-16-2014
13:32
19:50
LucyAP
07-16-2014
13:32
19:50
LucyAP
The support people over at Digifit seem to think that their app should be updating HRM info on Fitbit but it's not showing up on mine either. Would like to see HRM data in dash as well... Digitfit info should be showing up according to Digifit... From Digifit support: >Ah, thank you for the information. > >Did heart rate from Digifit ever show up for you on Fitbit? We have not made changes to information that is >sent to Fitbit. Have you tried contacting their support team to see why this information is not displaying? >They can be reached at contact.fitbit.com.
07-16-2014 14:05
07-16-2014 14:05
Sam | USA
07-16-2014 15:18
07-16-2014 15:18
07-16-2014 15:20
07-16-2014 15:20
Digifit does not pass heart rate data to Fitbit; and doesn't claim to. The claim relates to the accuracy of the calorie burn for exercise based upon the heart rate data it monitors; there is no doubt that HR based burn values should be more accurate (though there may be an argument on their unpublished algorithms). Digifit calorie burn values trump Fitbit.
07-16-2014 16:48
07-16-2014 16:48
It certainly appears that Digifit is claiming that HRM data is passed to Fitbit in their press release on their
website... see http://tinyurl.com/os66j9e
"...or pull their heart rate monitoring information into their Fitbit dashboard." would certainly seem to imply
more than just calorie data.
It would be nice if it there was more to it than that.
