01-25-2015 18:15
01-25-2015 18:15
I'm not sure if it's better to log burpees and the elliptical in myfitnesspal or to just let the fitbit track it. I just got off the elliptical for the second time today, and my dashboard shows 108 active minutes, altough was on it for about two hours both times and did 100 burpees. I don't get it. I can't tell if my calories burned are accurate. Any feedback would be appreciated.
Best Answer01-26-2015 04:54
01-26-2015 04:54
I hope you are doing great today @SunsetRunner! It's great to hear that you are using your tracker and My Fitness Pal to track your daily progress. To answer your question, I suggest you manually log this activities on MFP in order to register accurate data, since the tracker is specifically designed to track stepped based activities while you move forward.
Give this a try and let me know if you have any other questions. ![]()
Best Answer01-26-2015 08:06
01-26-2015 08:06
