10-06-2016 20:28
10-06-2016 20:28
Is it possible to log food into MFP and have to carry over to fitbit dashboard? I've exhausted all options I can think of. Any ideas or is it even possible?
Thanks, Tim
10-07-2016 15:41
10-07-2016 15:41
Allow me to help you @Timcote80! Yes, actually the integration will work like this: MFP will send activity, food and weight and Fitbit will sync steps and weight to MFP.
Can you double check that you've linked correctly your apps? Go to your Fitbit Dashboard > click on settings > applications > there should appear MyFitnessPal.
Let me know how it goes!
