03-03-2014 10:12
03-03-2014 10:12
is there a fix or any advice for this?
Best Answer07-01-2014 06:57
07-01-2014 06:57
Hello @MistyN79 - A warm welcome to Fitbit Community! Perhaps MyFitnessPal Integration update can help you and check if you have the latest version of the Fitbit and MyFitnesspal applications.
I recommend that you try disconnecting and then reconnecting the apps. You need to go your Profile apps > under MyFitnessPal, click "Revoke Access." You can then re-link the two accounts by going to MyFitnessPal.
Also, my apologies that you didn't receive a reply before.
