06-25-2014
04:33
11:16
06-25-2014
04:33
11:16
I recently bought a flex and is doesn't sync with myfitnesspal correctly. Also, how do you use the pc insert after using it at the gym?
Moderator edit: formatting
Best Answer06-25-2014 11:25
06-25-2014 11:25
@dolphin20009 I'm sorry to hear about that. What specidfic issues are you seeing with MFP? I always recommend unlinking and re-linking the accounts to be safe and to see if the makes a difference.
Also, are you referring to the dongle? Please check out this help article for specific help with syncing to your PC. You can also sync to your smart phone/tablet, depending on the type you have.
Welcome to The Community!
