02-02-2016 03:12
02-02-2016 03:12
I have issues with the syncing with my fitness pal. I would like to carry on using it as the calorie logging is great but when I log my fitness it doubles up. Is there any way to make sure that when I log my fitness it goes into the activity log - so the 30 mins of exercise is attributed to a spin class?
Best Answer02-03-2016 05:30
02-03-2016 05:30
Welcome to the forums @fidgetgreen! This is an odd situation but I'll be glad to help on this. ![]()
In this case it's best to relink your MFP-> Fitbit accounts like this:
A couple things to consider about your MFP - Fitbit Integration:
Hope this helps! Let me know if you have any questions ![]()
02-02-2016 10:46
02-02-2016 10:46
Where are you logging the activity? It should not be doubling up unless you are logging it in both apps, or both apps are connected to a 3rd app which is causing it.
Best Answer02-02-2016 12:12
02-02-2016 12:12
02-03-2016 05:30
02-03-2016 05:30
02-03-2016 16:04
02-03-2016 16:04
I'm having the same problem but these instructions do not work for me. I did steps 1-6 (including 3 that said "disconnect") but when I logged back in to click on "Connect" it said "disconnect" & the Active Minutes on Fitbit are still double. I tried it again & this time after disconnecting & logging out of both apps I deleted both apps then downloaded & logged in & it still says "disconnect" & the Active Minutes are still doubled. Any other suggestions?
Best Answer02-09-2016 10:45
02-09-2016 10:45
Welcome to the forums @Heathersr! Quick question, are you logging exercise through MyFitnessPal? If you are, please delete the logs, sync your fitbit and refresh your MFP dashboard.
Keep me posted!
Best Answer02-10-2016 05:09
02-10-2016 05:09
I am logging my exercise through MyFitnessPal. Does this mean I will not be able to log them in MFP? I would rather log in MFP & have it double in fitbit than not log in MFP. I've been using that app for about 4 years & lost 55 pounds with it so I don't want to discontinue using it to log everything. I was just hoping that I could find a way to log in MFP & not double in Fitbit.
02-16-2016 12:11
02-16-2016 12:11
02-23-2016 08:53
02-23-2016 08:53
Thank you for your responses @Heathersr and @Tykelass!
@Heathersr We recommend that all food and water items must be logged through MFP and your steps, exercises, manual logs and other activities need to be logged through Fitbit; this will prevent any double logging or incorrectly increasing your caloric budget for the day. They connect seamlessly and transmit information between eachother so your caloric budget is on a continuous update.
In @Tykelass' case, your SmartTrack kicked in and tracked your Racketball as a Workout.
PS: Welcome to the forums @Tykelass! ![]()
Best Answer03-26-2016 15:34
03-26-2016 15:34
Best Answer04-20-2016 01:42
04-20-2016 01:42
I have a similar issues. Although im not 100% sure whether it is double logging or not and i can't figure out if it is. So i have Fitbit app (using Charge HR) , I use myfitnesspal to log food and i use mapmyride app to track my cycling. So they are all linked. Once i have completed my cycle on mapmyride it syncs to MFP and this inturn syncs it to FB app which is all fine, as my fitbit recognises the time and puts my heart rate etc for this time. However on MFP you get the calorie adjustment based on your activity and exercise so for example if i go to yesterdays log in MFP at the exercise section its says:
'Bicycling, touring bike, 46 mins, 396 calories' then
'Under Armour Calorie Adjustment, Based on your measured activity, 912 calories' (this is the info from my Fitbit) so a total of 1308 calories under exercise section, then if you click on the underarmour one it ives you a breakdown of how it got that number so it gives the following:
How we calculate your adjustment:
Under Armour Calories burned 3054 (this is a full day projection nased on calories urned as of 11.29pm)
MyFitness Pal Calories Burned 2142 (includes 396 calories from exercise, which is my bike)
Under Armour Calorie Adjustment = 912
So do you think the 1308 total calorie adjustment is counting the bike ride twice? once on its own and once in the adjustment?
Thanks in advance.
I hope someone can follow thiis
06-01-2016 11:27
06-01-2016 11:27
Thank you for your responses @allblack and @SusannaMoss! In this case I recommend to check if there's an update for the MyFitnessPal App as well as the Fitbit App for your mobile device.
However, in your case @allblack; it's best to disable the 'Under Armour Calorie Adjustment' since it's duplicating your activity that has already been processed on the Fitbit Dashboard through MapMyRide.
Best Answer06-01-2016 12:04
06-01-2016 12:04
06-01-2016 12:07
06-01-2016 12:07
That is excellent news @SusannaMoss! I'm glad to hear you are now back on track.
Hope to see you around the forums! ![]()
PS: Have you checked our Discussion boards? They are full of fellow fitbitters like you ![]()
Best Answer06-19-2016 09:42
06-19-2016 09:42
Best Answer06-20-2016 23:01
06-20-2016 23:01
Best Answer06-21-2016 01:24
06-21-2016 01:24
06-22-2016 23:17
06-22-2016 23:17
Best Answer07-20-2016 04:13
07-20-2016 04:13
Great to see you around @Jojoflojo and @Tykelass. Keep in mind that if you have a MFP account and you are logging your activities there, it will transfer the information to your Fitbit account and it might double your information. I recommend logging your activities just in one account, Fitbit or MFP to avoid the duplicate information.
See you around! ![]()
Best Answer07-21-2016 07:59
07-21-2016 07:59
