01-02-2018 12:54 - edited 01-02-2018 12:57
first i had connect an my old strava account; after revokes acces, now
it is not possible to sync fitbit ionic with my new strava account: in the settings appears: "account: anonymous+74595dcd-cbbac@strava.com" en not my account : i don't can change this account
i follow this instructions: https://help.fitbit.com/articles/en_US/Help_article/1727 and have an iphone (and mac pc)
Best Answer01-04-2018 08:42
01-04-2018 08:42
@tonyvandersteen Thanks for your reply! I made some research regarding why is it showing the authorized email address like that and it is for security purposes.
Strava is using an email alias so your personal email isn't displayed on the account.
If you are connected and it is syncing, it should be fine and working properly. Have you tried syncing since you got it linked and authorized?
Keep me posted! ![]()
Best Answer01-03-2018 07:16
01-03-2018 07:16
@tonyvandersteen Welcome to the Fitbit family! Please revoke the access from Strava once again, and re connect both apps. Make sure to link Fitbit with your new Strava account.
Once you have linked both apps, do the following:
This means that both apps are now connected to the Ionic itself. From this moment, all the GPS activities you track with the Ionic or Strava will show when you tap the Strava App within the Fitbit Ionic.
Please consider:
Hope this helps. Let me know how it goes! ![]()
01-03-2018 15:53 - edited 01-03-2018 15:55
Until :"You will see a screen with an "Authorize" option. Tap it." No problem but then: "Wait a moment, this may take some minutes, but you should see "Authorization State: Authorized" and your Strava email address under "account". You will also see your email under "Strava Login"." This does not work: if i tap authorize: a pop-up appears with the words " do you open this page with Fitbit?" and you have two options: "annulation" (if you tap that option: a wite screen appears and nothing happens) and "open" (if you tap this option: "authorization state: authorized" but account: anonymous+74595dcd-cbbac0@strava.com and not my account)
01-04-2018 08:42
Best Answer01-06-2018 08:49
01-06-2018 08:49
no synchronisation ![]()
Best Answer01-08-2018 06:50
01-08-2018 06:50
@tonyvandersteen Thanks for your reply! Is it still showing the alias email under "Authorization State: Authorized"?
How are you tracking your exercises? Please consider the following:
Are you tracking the activities like that?
If still nothing, you can try deleting the authorization and starting the connection process from scratch. That should help for sure!
Best Answer01-08-2018 07:00
01-08-2018 07:00
I have to re-authorise the app every time I want it to sync (even though I've clicked 'keep me logged in', and then app says that it's authorised). It simply won't sync the activities to the ionic unless I do that. Makes the app a little pointless to be honest.
Best Answer02-20-2018 22:45
02-20-2018 22:45
could try rebooting the Ionic. i did then my rides were uploaded to strava and strava data was updated on the Ionic.
04-11-2018 01:53
04-11-2018 01:53
Hello:
If I follow
Best Answer01-11-2019 08:10
01-11-2019 08:10
I have done what you say but I can’t see my activity on Strava, it comes up blank? I only see it on the Fitbit app but I want my runs to be in my strava app too? Is this possible
Best Answer01-11-2019 08:21
01-11-2019 08:21
Best Answer01-11-2019 08:35
01-11-2019 08:35
Best Answer06-15-2020 13:26
06-15-2020 13:26
Hi
my Fitbit Ionic is linked to Strava but on my Strava on my watch it says link account to which it is.
Any ideas as to why it won’t work
Thanks
Di
Best Answer06-15-2020 13:27
06-15-2020 13:27
Best Answer06-15-2020 13:34
06-15-2020 13:34
I have tried emailing Strava but no reply yet?
Thanks for your feedback
Di
Best Answer06-15-2020 13:48
06-15-2020 13:48
