06-09-2017 07:39
06-09-2017 07:39
I am having trouble syncing my fit bit to my fitness pal.
does anyone know what the problem is ?
06-10-2017 09:24
06-10-2017 09:24
I have the same problem. It sees that it is connected but doesn't sync. Did you connect your device in settings?
Best Answer06-10-2017 18:44
06-10-2017 18:44
same problem
Best Answer10-06-2017 17:35
10-06-2017 17:35
I have the same problem. Mine stopped syncing with My Fitness Pal in August. Uninstalled and reinstalled both apps, disconnected and reconnected both but no luck
