03-03-2015 08:55
03-03-2015 08:55
For the last week, I have had to re-link my Surge to MFP after every meal in order for it to sync. I would ditch MFP and only use Fitbit for calorie logs, but FitBit currently does not suppor a weight gain program (necessary for me).
This is incredibly redundant and ineffecient, and it is only MFP that I am having this issue with. My other apps are syncing with no problems. I have gone in through FitBit settings and reset the link, as well as through MFP, many many times.
Again, I need to continue to use MFP until I am at my healthy weight goal, and that means gaining a few more lbs. The combination of MFP and my Surge have been incredibly helpful so far in monitoring my calories in vs (actual) calories out, and I really hate losing that functionality.
Please advise!
03-03-2015 09:06
03-03-2015 09:06
MFP was having issues yesterday. They seem resolved now, at least for me. How long have you waited for the sync to occur before disconnecting and reconnecting the apps? BTW, MFP syncs with your Fitbit dashboard, not directly with your Surge.
03-03-2015 09:28
03-03-2015 09:28
Usually when I disconnect/reconnect MFP with FitBit, the calories already logged show up within a few minutes, if not immediately. However, if I go to log more in for the day, they will not show up until I repeat the whole song and dance of disonnecting/reconnecting.
As of a few minutes ago, even the disconnect/reconnect ritual is not syncing the two programs anymore.
03-03-2015 14:12
03-03-2015 14:12
This is beyond a joke, hopefully MFP will get their act together soon. Unfortunately there is no other app which offers all that MFP does.
03-03-2015 20:16
03-03-2015 20:16
@AnnaKBush wrote:As of a few minutes ago, even the disconnect/reconnect ritual is not syncing the two programs anymore.
Because MFP is admittedly having issues. Mine accounts weren't syncing yesterday morning, but seemed to work ok in the evening.
03-05-2015 14:43
03-05-2015 14:43
03-29-2015 05:59
03-29-2015 05:59
So I just got the surge and I think I synced it with myfitnesspal. Do I have to enter food twice or should my entries on MFP show up on the fitbit dashboard?
I have been searching and searching for this question and havent found it yet. Obviously Im new 🙂
03-30-2015 06:58
03-30-2015 06:58
03-31-2015 02:47
03-31-2015 02:47
Just log food in MFP and Fitbit will sync "meal summaries". You won't see the individual foods synced in Fitbit, but if you're logging in MFP you probably don't care about that. Fitbit will get the calories, protein, carbs, etc. from MFP totaled for each meal.
02-29-2016 06:00
02-29-2016 06:00
04-26-2016 13:41
04-26-2016 13:41
Hello there @AnnaKBush, @tastybrew, @loulouthrumbly and @Bayah! Thank you for your updates and for your work on this. Please keep me posted with any update you may have about the way your Fitbit and MFP apps sync.
@Wendoger You only need to enter your information in one side. Once your accounts are linked, they will sync the information automatically. Here a chart that show the way how Fitbit and MFP share your info. In that way you'll choose where to log it.
What syncs? |
Fitbit > Steps > MFP |
Fitbit > Calories > MFP |
Fitbit > Aria measurements > MFP |
MFP > Logged food > Fitbit |
MFP > Activities > Fitbit |
@ErikG To link your accounts you only need to go to your MFP account and look for the option "Works with Fitbit" and follow the instructions provided.
Hope this helps!
