01-10-2017 06:12
01-10-2017 06:12
I just switched to a Charge 2. When I go to Compatable apps in the account setting and click on WW, a message "This app is not available for you device". Is this unique to the Charge 2? Which fitbits are compatable with WW?
Best Answer01-10-2017 08:39
01-10-2017 08:39
Hi @AZSAM,
If you are still having trouble with connecting your Fitbit and Weight Watchers, I'd recommend that you revoke access to Weight Watchers and then start from scratch with linking the two accounts.
Hope this helps!
Best Answer01-10-2017 06:21
01-10-2017 06:21
You need to lnk it from the WW site
http://help.fitbit.com/articles/en_US/Help_article/1570/?q=weight+watchers&l=en_US&fs=Search&pn=1
Wendy | CA | Moto G6 Android
Best Answer01-10-2017 06:44
01-10-2017 06:44
Best Answer01-10-2017 06:46
01-10-2017 06:46
I should have written "redirected to step 5"
Best Answer01-10-2017 08:25
01-10-2017 08:25
Then I think you need to contact WW. They should set it up do that you can link it.
Do contact them
01-10-2017 08:39
Hi @AZSAM,
Hope this helps!
